Fairly sure that a tug won't be using a flex shaft. Flex shafts are good for forward only, tend to have a lot of end play and also tend to unwind themselves when reverse power is applied. A boat that reverses (like a tug) needs to have things fixed so that the rigid shaft can rotate easily, but doesn't allow the prop to mash itself into the rudder when reverse is applied.
