I finally put the maiden on my Corsair!
You can hear the engine is rough on take off, and on the second circuit I throttle back half and it smooths out.
After the flight I adjusted the high needle to max RPM and backed it off 1/8 as suggested above.
I am getting about 6,000 RPM.
Again there is hardly any difference between half throttle and full?
Is that typical of these engines?
The throttle response is smooth otherwise.
Just not sure what to to from here.
Kevin
