Did someone say smoke?
Powerbox dual outlet with 2 dreamworks sticks. You have to be very carefull when you back off the throttle to near idle. If you are still pumping smoke oil you will get a afterburner fire when you come back on the throttle.
Better have a good Pipe! I have the Tams pipe so no harm here.
Kynetic smoke oil. The Best out there. I can get good results in the cooler months with keeper oil but when it gets hot it doesn't compare to the Kynetic.
