RCU Forums - View Single Post - Boat steering problem
Old 04-26-2017 | 04:15 PM
crapshooter
yes as mentioned, reverse servo direction by the transmitter or if applicable you can just remove the arm from steering servo and rotate it 180 degrees . is the radio Hitec Optic brand ? also do you have any other models set on this transmitter ? if so you could have the wrong model .
