Originally Posted by
Pork Chop
Go back and look at post #27 I had horizontal stab issues too. I built per the plans and when I test fitted the vert stabilizer the angle was off! Easy fix and it was really the only issue I had with the kit.
Thanks, I checked that post and unfortunately when I clicked on the photos nothing came up.
Guess I'll just go ahead and build the horizontal stab according to the parts fit and go from there. It's not off by very much from the leading to trailing edge leaves a 3/32" difference from trailing to leading between the plans and the actual fitting. That is the stab is narrower by that much.
I don't believe it will make much if any difference at all.
Gonna go back through the entire thread just to more familiarize myself with this one.
