If you clip the wing, I would think that the low speed flight would get worse. You also have to consider how much more weight you are applying to the lift of the wing if you clip it. You are going to make your wing loading greater by clipping the wing. The usual thought process is the higher the wing loading the more speed you need. Good Luck, Dave
