Bob, If those gray wires are the antennas, you should isolate them from all other wires as much as you can. This is especially true if the other wires have power in them. Don't forget the all important range check before the maiden. Try to do a 360 degree walk around. Good luck. I appreciate you letting us join in. Dan.
