RCU Forums - View Single Post - RUDDER - CABLES or ?????????
Old 05-03-2017 | 09:26 AM
onyta
ONYTAY HERE, I DON'T HAVE A PROBLEM WITH 'EM, JUST THOUGHT MIGHT BE SOMETHING BETTER.. THE COUPLING WITH THE HOLE IN IT THAT
COMES WITH THE ESCAPADE HARDWARE THAT GOES IN THE PLANE ON THE SERVO HORN COULD WEAR-OUT IF THE PLANE LASTED
LONG ENOUGH.....FISHING(STEEL,ss,LEADER ) SOUNDS LIKE GOOD STUFFFFF...I SOLDER & CRIMP THE THINGS AND HAVEN'T HAD ANY
TROUBLE BUT HAD TO TAKE SOME LOOSE AND THE ONLY WAY TO GET EM OUT WAS TO CUT.( IN A HURRY).
THANKS FOR THE QUICK REPLY & THE INFO..
NOTHER QUESTION ?????????? DO SERVO ARM SCREWS NEED THREAD LOCKER IF THEY ARE METAL GEAR SERVOS. I HAD 1 COME
OUT, FOUND IT IN THE WRECKAGE , LOST RUDDER IN A BAD CROSS WIND-CAUGHT WING TIP ON TARMACK, CARTWHEELED ESCAPADE,
HAD 2 ESCAPADES AFTER THE CRASH LANDING, BROKE IN TWO(2) PIECES........MADE A FUSE. JIG & FIXED THE SUCKER....ONLY NEED 2
FINISH THE CONTROL CABLES AND UP AGAIN........
THANKS AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
