RCU Forums - View Single Post - PAW Diesel 40 TBR Run-In Experience
Old 05-03-2017 | 10:32 PM
Lou Crane
Gaz, to your #15...
Thanks again for the great info and several clarifications!
I am not a analytical chemist, so I may be a bit confused by a difference between 'dissolves into' and 'dissolves.' Is there a chemical change to some other substance when ether (or nitromethane - another excellent solvent) "dissolves" an oil, or a liquid like our kerosene? If so, what do they change into?
I should have connected a few dots earlier... I've mentioned that I accept that the weight (mass if you prefer) of the propellant in John Deere Starting Ether gasses off at our usual temperatures, leaving the quoted 80% of mass as liquid ether in the standard spray can. Conversion per Specific Gravity numbers increases the volume (cc, not gram, numbers) usefully.
More? Please...
