Wow.. I have so many to build that I am simply setting them up for later decisions... I'm of the school of.. "get em while you can" I can never seem to find things once I've passed on the for what ever reason. So if I see something in 1/16 scale and it is WWII era or even Veitnam in some cases I get it and try to get all the extra parts needed
to do the intended mod. In this case it started with the 1940 Ford Stake Truck... I looked at the Asiatam Opel Blitz...a but too expensive for what I was thinking of... I ended up getting the Ford after seeing a German War time photo with the same truck with an AA gut on back bed. So then I'm off looking for a Flak 38 as I already have the Verlinden Flak 43 and the Hungarian 3.7 CM Flak kit.. both of which are slotted for a Bergpanther D with Flak 37 and Mobelwagen 3.7 cm Flak (Late) ...I also have the Juckenburg Whirbelwind...
I plan on mounting the Flak 38 onto the back bed of the Ford... it is a static kit, but well detailed and basically its a battlefield prop... they all can't run, jump, and shoot. All the others pretty much will do that if I ever get around to it before the MS makes it no longer possible.
I've attached a few pix.. the Black Ford is the truck I purchased.. the Flak is the Battle ground kit,, the rest are reference images I like and probably the direction It will end up going... I have a set of Xion
figures that will fit... but that is the last thing I think about.. and I always mod the figures to my tastes anyway.. I hope this sort of explains my thinking Thanks again.. Joe
