Originally Posted by
Hydro Junkie
P-38 Lightning
Hydro Junkie; the P-38 could out climb the P-47 and P-51; so that won't work. But here's a bonus clue for you. Thanks; Ernie P.
Question: What warbird do I describe?
Clues:
1.This fighter aircraft was noted as being a very effective dogfighter.
2.It was capable of fighting on equal terms with almost any fighter of its day.
3.Much of its success was related to innovative methods and equipment which helped the pilot better control the aircraft in combat situations.
4.These methods helped the pilot turn the aircraft quickly without losing control; and automatically compensated for quick turns and combat speeds.
5.It wasn’t an easy plane to fly, however; and so was assigned only to experienced pilots in special units.
6.Unfortunately, it was not noted for being able to climb quickly, and the performance of its engine at higher altitudes was also less than ideal.
7.But its roll rate was very good; and it was noted for being able to both deal out and absorb punishment.
