RCU Forums - View Single Post - Engine Trouble
Thread: Engine Trouble
Old 05-19-2017 | 03:02 PM
Jonas4sberg
Originally Posted by F4 Phantom blue angles
A two stroke is a simple engine,no matter what the size. You need fuel,air,and spark. If not an oil problem,make shure your high speed port is clean. These holes are extremely small. Use a fine peice of wire to clean out. You might have a defective needle valve. It might no be closeing all the way. I would have to have it here to figure it out. Check all your gaskets. Let me know how it goes.
Lucky
Well like i said above i tore the whole thing apart earlier, even the engine, it was clean as a whistle, wasnt even visible carbon yet. I put on the new glow plug i got and it instantly seemed to idle better, but it seemed to be spitting out a lot less smoke so I began making the HSP needle richer, and the richer i got the more throttle I could guve it until i can now give it full throttle even when its a little cold and ot doesnt even bog down. Guess it wasnt burning all the fuel cuz of the glow plug. Runs perfect now! Thanks yall!
