RCU Forums - View Single Post - Tamiya King Tiger Build
Old 05-19-2017 | 04:46 PM
  #59
tpallas
Moving on with the build....finished up the DT idler system. It may need some adjustment when the whole tank is done but for now I think it's sufficient. I was a bit intimidated when I first got the kit and instructions but it wasn't as difficult as I thought it would be.
Since I'm using a Spektrum DX9 I had a friend install the correct servo leads to the DMD control unit.
Installed the controller stack, everything else roughed in.
Any advice or best practices on how to tidy up the wires? They are pretty thick and it seems like you just mash everything together the best you can and zip tie it up?
