Spark Plug color
The picture is a spark plug from a 40cc RCGF twin cylinder engine. The engine is running good, but I decided to pull the plugs to have a look at them. Is it possible to tell from the attached picture if the high speed needle is set too lean or rich? The engine was run at full throttle for about 30 seconds and then shut off right before I pulled the plug.
