RCU Forums - View Single Post - Seized fox 35 engine
Old 05-22-2017 | 06:42 PM
the Wasp
rinse it first with rubbing alcohol let it dry,,
if it is going to set for a year or 2 use ATF..
you can use ATF if you are going to start it in a couple weeks or months, but make sure you rinse the engine well with fuel before you start it to get the ATF out
Jim
