Originally Posted by
franchi
Hello Gazimoto:
BINGO! I think that you may be on to something! I bought this engine "NEW" from a dealer who sold Diesel engines and supplies. I have not disassembled the engine. I will check the rod.
Thank you very much,
franchi
Otherwise the shaft may be displaced a bit towards the backplate, and/or the rear race may not be correctly seated in the crankcase. While the rod/piston/liner is out, gently heat the engine up to just under 100 degrees C and tap the crankshaft forward sharply a few times. I have made a brass punch to do this. One end has a step machined in it and the smaller end just fits into the induction hole. Reassemble and check the crankpin clearance.
