RCU Forums - View Single Post - P-70 code.
Thread: P-70 code.
Old 05-25-2017 | 04:53 PM
johnf-4
Post P-70 code.
Can someone tell me what the letter 'E' flashing alternately with the temp when I go over 100.000 rpm on my P-70. It has version 6.10C ECU which is a new ECU.
This ECU has more functions than the old ECU but can't see anything in there that I think would cause this. This happens if I throttle up slowly or rapidely but only starts after I pass through the 100,000 rpm mark. Temp is running around the 570 mark and just over 690 on a rapide axcelleration.
When I slow it down below half throttle it will go away after about a minute. When motor is first started I can throttle up and it will go to 123,000 rpm and run for about half a minute before the letter E appears. When the letter E is present it will only throttle up to about 121,000 -122,000 rpm and only idle at about 39,000 rpm. When letter E is not present it idles as it should at 38,000 rpm. The letter E dose not appeaer at the same temp each time.
