The complete interior of the fuse from the turbine mounts back to the last bulkhead (and the wing recess) was covered in BVM Heat Blanket and High Temp Aluminum Tape. Here you can see the first section that I applied. This may seem unnecessary but in the event of a hot start or fire it will be worth it to me. As you will see I over protected all the wiring as well. To me this is a small weight penalty to pay for piece of mind.
