you should get used to sharpening and balancing props as this is definetly not hard to do for anyone i might add. by the time you get someone to do this job that would pay for a good balancer and all you need then is a file or two and some fine sandpaper to finish off. so think about this as it is fun to work on your own gear. also as mentioned, don,t run a 3/16 inch shaft on a gas powered hull [ 1/4 inch is a must ] plus you have bugger all variety of props to try with 3/16 inch i.d. 470 - 472 - 270 - 275 try any of these as there all good.
