Originally Posted by
olnico
Yep. I can still do tires. I need dimensions for the standard YA rims!
I have the Dennis wheels but they are different.
Oli,
Here are some photos.
The inside of the yellow foam tire is dia 51mm x 36mm deep. For reference (may not be scale) the OD is 97mm and the width of the tire is 37.5mm.
The rim is split in two and together the dims are as shown in the photos. the depth with the depth gauge is 5.45mm.
Let me know if you need any other dims.
This is what I have on the full size tires:
- Main Wheel tires (qty 1 per side) size 30 x 11.5-14.5
- Nose wheel tires (qty 2) size 22 x 6.6-10
Also, see the following link, it shows the exact labeling for the tires:
