RCU Forums - View Single Post - Can a fuel tank cause over compression????
Old 05-31-2017 | 03:34 PM
qazimoto
Frank is flying control line models so he needs to take off richer than radio model engines.
The fact that it took half a tank full of fuel in the air before it "went hard" suggests a tank or fuel feed problem to me. The symptoms suggest a partial fuel blockage causing the engine to go over lean. Could be some "grunge" in the tank. A flush with kero both ways may clear it. A fuel filter is often a good idea.
