Originally Posted by
papatrey
Just got the balancer/angle meter yesterday. When I try to connect to BT, it finds the device, but says it is not validated so I do not get any weights or measurements?
What do I need to do to validate it?
It also will not connect to BT4 even though the phone (Galaxy S7) has 4.2 BLE.
First you should do a search for Bluetooth devices.
The phone will display a list of BT devices found. Select the Xicoy CGMeter on the list.
The phone will connect to the BT module. Once connected, the app will go to main screen and show the text "Press button on the XCM device". At same time the RED light on the BT module will lit, confirming that the phone has been connected. Then you should press the button on the module (close to green led) to confirm that you own this device.
Gaspar
