I am building the smaller 74" version and will be adding the small vertical fins ( for lack of the correct term) behind the leading edge in alignment with the alerons.
According to a recent AMA mag article certain type wings can benift from this addition because they add lift and would make the wing tip less prone to stall.
Do you think the larger version could benifit with these additional mods ?
