RCU Forums - View Single Post - M32 Build
Thread: M32 Build
Old 06-11-2017 | 09:56 AM
RichJohnson's Avatar
RichJohnson
OMG, banging my head on the wall to get this forum to load my pictures for a couple days now. See if it works.
Shown is one of the pivot hinges I made, one was a pain, two were insane to fabricate. It took many trials and fails and many burned fingers to do this. I was determined to make them from brass rather than plexi so they would never break.
I had to remove all the cross bracing from the A frame boom to make it narrow enough to fit the Ford A3 hull from Nick Aguilar. Now, problem is the Turret is too wide to fit between them, but I know I have the hinge pivots in the right spot and the rear A frame is just about correct, give or take a MM so..... Weighing options on how to proceed, seeking help from those that may know better on other forums....
ID:	2219611   Click image for larger version
ID:	2219612   Click image for larger version
ID:	2219613   Click image for larger version
