RE: TF 1/5 Scale P-51 ARF Assembly Thread
Gary, what are you doing about the tailwheel doors? I haven't been able to get them to work (close) My retractable tailwheel has pulled one side off. the other side seems to move just fine, but the angles are all wrong on the brackets and the supplied rubber bands will not close the door when the gear is up. Did you have this problem, and if so, what did you do about it.
