Originally Posted by
RustyUs
EXT2 looking good with fresh rubber
. That taller tire was my concern as well. The only tires I can think of ...another pair of Gladiators! They will pretty much last years before needing replaced. That is of course if running off-road. The size of Pro-Line Gladiators is quite a bit taller, as you found out, than normal stadium truck tires. You will also gain a bit more bite when using the Gladiators up front.
Cheers buddy. Yeah that's what I was thinking of
