Originally Posted by
MaJ. Woody
Thanks Marty. You and Mark both mentioned low rate but unless I missed it, the manual only gives one rate. Can anyone tell me the travel for low vs high rate on the Ailerons and Elevator. Thanks for all the feedback everyone.
The memory ain't what it used to be. I think when I set up the plane I set up dual rates and my low rate is less than the recommended single rate that is given in the manual. Probably about 20% off of the recommended rate. So that is what I mean by low rate. The recommended rate was too sensitive for me even with expo. It might be perfect for you but it's always good to have "on the fly" options for a maiden and then remove them once you have it dialed in.
