Originally Posted by
wlavigne
I looked but no luck.
I have a drawbar from another engine. Let me see if it fits my GS45. I believe the .45 and .51 use the same carb drawbar. As for the carb base o-ring - go to a local hardware store with the carb in hand. Find an o-ring that is just a tiny bit smaller diameter than the neck of the carb. OR a you could put a thin bead of sensor safe RTV silicone around the base of the carb.
