Originally Posted by
mick15
Having read these endless threads regarding Festo and negative pressure I carried out out some physical tests requiring the disassembly of a number of 4mm fittings. Here are my findings hoping to clear up this issue (though I doubt it lol)
All of the 4mm "small" fittings use an "0" ring of Festo design. This ring is of flat design containing a moulded in o ring this design makes the fitting of the tube easy as the tube enters the flat part of the seal then the extra pressure engages the tube into the o ring portion. This fitting is able to sustain leak free use in both positive and negative pressure.
The second type of 4mm fitting is slightly larger and has a different feel when fitting your tubing, the reason for this is simply the seals are of the "lip" design, and are totally unsuitable for the suction side of any application.
m
Thanks. This may explain some of the outcomes.
As I have already pointed out, 1 negative Bar air pressure rating is not much compared to the hydraulic suction force a pump can deliver. Admittedly, if you have high suction, there may be another fuel system issue. But I agree with Dr. Honda and stick to using Festo pressure side only. Why introduce more bubble risk when you don't have to.
