Hello, more update
As of now, all my surfaces are working well with an AR10000
Other information for thoses who it can benefit:
One important things is the calibration procedure - Alpha6 needs to see signals input in all ports that you have connected and this is consider in the calibration process.
If for example your did not connect the ailerons inputs, they wont work until you recalibrate having them connected.
Same thing for flights modes, you do not need only to set this thing up but you need to recalibrate should you change an input signal.
Other informations on the led colors in normal operating modes:
White - you are at 0 - so there is no Gyro action
Purple - you are in the 0 to -100 range - therefore opting for Heading based on default config on Elevator and aileron and Rates for Rudder
Green - you are in the 0 to 100 range - therefore opting for Rates based on default config on all surfaces
On your monitor screen you can see the % if you are applying if you use the knob it is pretty easy I assume to make in flight adjustments and explore Rates versus Heading Gyro assistance.
Hope that helps
I'm still not able to setup correctly flights modes - I saw only two modes and not in the sequence I set them.
May I will found how and post it before some replies came back!!
Any cue ?
Patrice
