Originally Posted by
RustyUs
There are Evader users that have gone one an extra step in ultimate motor mounting toughness. Using two motor mounts to eliminate flex on the rear end. I personally have not seen the need to go this far into modding the Evader platform. Over the years, the little gap (mesh) between the spur/pinion gears has proved to be enough of wiggle room for my Evader. If you are slapping the ground hard off of jumps and whatnot, then possibly shock tuning is needed.
Get out there and throw some dirt!
True it was only a spur, my gear mesh was set correctly though but I was driving the car erratically to be fair. I can't be bothered modding the rear end so i'll pass on that one haha... Anyways gotta get the car up and running again!
