RCU Forums - View Single Post - Looking for "micro" Jet Drive for 1/72 Scale Boat
Old 07-05-2017 | 02:30 PM
Got RPM's Avatar
Got RPM
An easier approach would be to use a "tunnel drive" system. This uses a normal prop drive, but it is positioned in a tunnel built into the hull bottom (see below). Not quite the same as a true jet drive, it is far easier to make for most hulls and with similar performance.
https://goo.gl/images/GLnUMY
