It's funny how some seem to think it's a no no for running the two batteries in parallel to one ECU. Regardless if you run one or two or 100. If you have a short anywhere in the system which runs that turbine it will most likely shut down. Running batteries in parallel is NOT to prevent a shut down if a short happens.
Thank you all
