Thanks Luke.
Thanks Erik, most of what you shared about modular design etc is what I already agreed on earlier
But I did earlier lookup sabertooth 2x30 suggested by someone here and it was over $100 !!
So where do I find the cheap ESCs you're describing? And bare in mind, although I used Imex gearboxes in all my tanks, I use the long red 480 motors. HL 2.4 board has no problem controlling those, so I'm assuming Taigen board would have no problem too. Are they using 2x20 or 2x30? Basically, would the cheap 2x20 you're describing be as strong as the ESC mounted on Taigen and HL boards?
