Good point on the differential. Hadn't thought about that.
How will I know if the servo is being over-taxed? Currently set up using Futaba S3004 servo at 6 volts. Specs at 57 oz-in with full charge.
S3010 comes in about right and the same physical size but height. Will have to check the room in wing for that.
Thank you all for your input.
