I have a couple install questions for the 624 Rx. I will be using it in a 60 size sport model, with standard ply fuse , metal pushrods and glo engine.
Is it okay to wrap the 624 next to the battery in foam, or is it better to keep the Rx away from the battery a bit? If separated from the battery, is it still preferable to wrap in foam also? (I thought I read somewhere you should avoid wrapping the Rx in foam due to heat build up but wasn't sure about that.. ?)
Should the short antenna on the 624 exit the fuse, or is this not necessary?
(I do know to keep the Rx away from servo wiring and metal pushrods as much as is feasible.)
Thanks for any info!
