The bared metal tip of the receiver antenna is the actual antenna. The rest is the coax cable. Mount the bared tip as far away as possible from wiring, the battery pack, from servos, and from metal pushrods. The antenna does not have to exit the fuselage.
You will not have any problems if you wrap the receiver in foam near the battery pack.
