RCU Forums - View Single Post - Hiec HG3XA gyro set up questions
Old 07-13-2017 | 01:59 PM
GrantL
Default 3 way position switch
Originally Posted by Paul Jarvis
Hi Grant........sorry for not getting back sooner.........use any 3 position switch and set it up just like "Dual Rates", except that the so-called "Off" position should have "20" which will give you a "blue" light and the rate postion.......the middle position should have "50" and that will turn off the gyro and yield "no" light........lastly, the last position should have a value of "80" which will give you "heading hold" and a "red" light........good luck, and let me know how it goes.......
Paul Jarvis (Team Hitec-Pilot)
Hi Paul,
I have a Futaba 72mhz 9c... I've asigned ch7 to the 3 way switch... when I go into the end point section.. I have 100% Center 100%
So... first switch is 100%, Center switch I'm assuming is 0% (off), and the 3rd postion is 100% opposite end...
What should I set these at?
Grant
