RCU Forums - View Single Post - Getting closer to an Open Source tank transmission
Old 07-20-2017 | 10:10 AM
maillemaker
Default Getting closer to an Open Source tank transmission
I have sourced the motors and the gears. There is a little machining to do in that a spacer must be drilled out slightly to extend the stock shaft that comes with plastic geared transmission.
The transmission frame will be 3D printed.
Steve
