I've used the CB100 in several airplanes but only with a single pack. This is where the real space and weight saving are. Using the available ports in the pair of R3's allows up to 14 outputs. This is IMO the perfect setup for the smaller jets. I'm comfortable with a single pack especially in these airplanes. In fact I use the CB100 setup in my DA70 powered 93" AJ Laser. Everything is run from the CB100 including the ignition.
