Originally Posted by
F1 Rocket
I've used the CB100 in several airplanes but only with a single pack. This is where the real space and weight saving are. Using the available ports in the pair of R3's allows up to 14 outputs. This is IMO the perfect setup for the smaller jets. I'm comfortable with a single pack especially in these airplanes. In fact I use the CB100 setup in my DA70 powered 93" AJ Laser. Everything is run from the CB100 including the ignition.
Danny, according to the CB100/200 manual the Rx1, Rx2 and EXT1 ports aren't current protected and have a 300 ma MAX rating. As a result nothing should be connected to the servo ports of the receivers connected to a Central Box if it will cause the load to increase beyond 300ma as it will DESTROY the central box. Unfortunately I found this out first hand..
