RCU Forums - View Single Post - Returning to RC
Thread: Returning to RC
Old 07-25-2017 | 06:43 PM
  #34
Hydro Junkie's Avatar
Hydro Junkie
Originally Posted by j.duncker
Always use 6v or better packs in the plane. If going higher than 6v make sure the rx and servos are rated for the higher voltage.
I strongly recommend you use professionally built packs with soldered or welded connections. Loose cells in holders have caused many a crash.
Why? I run digital servos in my 1/8 scale hydroplane that are rated at 4.8 volts for the throttle while the rudder servo is dual rated at 4.8 and 6 volts. The load on the rudder servo is several times higher than anything you will ever see on airplanes and it works fine at racing speeds on 4.8 volts. I've run a full weekend, totaling eight five to six minute heats on one NR4J 600mah 4.8 volt pack without recharging the pack. Come to think about it, I charged that pack with a "wall wart" charger a few days prior to that weekend, put it in the boat and never pulled the radio box tape off until I'd been home for three days
