Originally Posted by
Red Beers
Andy,
I have another airplane I would like to do the crow mix on, it's the red and white sport cub by Horizon. The difference is 6 channel receiver and 2 Ail servos and 1 flap servo.
RAL on channel 2
LAL on aux 1
Same flap system on D and crow on B position 1 (only position 1 is active, like above.)
The ailerons move with the flaps but the right one goes up and the left one goes down. How do I get the left one to go up?
Red
Go back and look at his post;
"Yes, very doable.
To get the ailerons to go up, you mix to LAL. This back-mixing will make both ailerons move in the same direction (if you mixed to RAL, it would be introducing roll instead).
Andy"
The back mixing is one of the trick programming things about Spektrum radios.
