RE: Need some mod advice
Forget about the CA debonder and get a heatgun. Apply heat to the joint you want to loosen and be careful you don't get it too hot, just a few seconds to heat up the joint and it should pull apart!
Another trick that works is if it's carbon fiber CA'd to carbon fiber you can take a small gel cell battery and hook up wire on either side of the area you want to remove. Connect the two areas with the gel cell battery for just a few seconds, it will heat up the carbon fiber since it conducts electricity and it will come apart.
Hope this helps!
Gary
