RCU Forums - View Single Post - Help with ESC setup first time
Old 08-08-2017 | 07:08 PM
RustyUs's Avatar
RustyUs
Originally Posted by lasse_hansen
I have now try to change place on the A and C cable on ecu/engine, and reverse channal on controller. But thats not helping.
I have now change everything back to how it was.
I dont understand what is gooing on, the car respond normaly.
When Use controller to go forward, the car go forward, and LED red.
When stand still, no LED
When use controller to go reverse, the car go reverse, and LED red.
when I drive forward and breake, it's breake slow and LED red.
When drive reverse and breake, its lock all tires and the LED is green about 1sek when i go from reverse to breake/stop.
And you calibrated the ESC's throttle range with transmitter? Before calibration, be sure to have Tx's throttle trim in the neutral position, and the throttle EPAs (low and high) set to maximum. The manual is pretty straight forward with calibrating the ESC. If you don't have GREEN LED at full forward throttle, something is not right.
