RCU Forums - View Single Post - Getting closer to an Open Source tank transmission
Old 08-11-2017 | 05:15 AM
Springman65
Steve,
I would also consider making a 3D printed motor mounting chassis with a full bottom plane with no chassis/lower hull mounting holes that would allow a buyer to make his own....a "GENERIC" that lets the buyer drill the holes and add bottom spacers for proper mounting...... Its a thought.....
If you can supply the outer diameter of the drive sprockets (assuming the right had drive or bevel gears are 1:1, a scale speed could be determined......
Springman
