RCU Forums - View Single Post - Skymaster AV-8B
Old 08-14-2017 | 07:48 AM
  #87
Likai's Avatar
Likai
Originally Posted by lavi rider
So the fan will be spun from the front part of the turbine ? Via a planetary reduction gear ? Where is the starter of the turbine be ?
The fan is driven by a secondary power turbine, not front part of the core turbine. Basically, the power plant is a two spool turbo-shaft engine similar to kingTech K-100 TP or JetCat SPT-15 but with different gearbox and powered by a K-210 core turbine, so the starter is located in the same place as usual.
