Originally Posted by
loopdeeloop
Pictures will likely appear as separate files rather than in the folder. No need to reformat as this clears the card entirely. Insert the card into your computer. Select the card (open it). Right click and select New Folder. Give it the same name it had before. Hit enter and the folder is back (empty of course but you can move any individual files back into it if desired).
so the bottom line is to keep the rpm's of the motor under control and for max thrust can I go to a 7 or 8 pitch ?
