oops oops oops I forgot,,
something else I know about Valve Float,,, is >>> when a valve floats the spring weakens, and at that the valve will start to float at a lower and lower RPM every time floating occurs, so this is another reason why I think Saito uses a spring will hold up to a higher RPM than just 11,000 or 12,000
Jim
