Originally Posted by
Rafael23cc
700 grams is 1.5 pounds! Yikes! I see two issues here, one the excessive amount of weight, and the excessive vibration that is making the weight move that much. So on top of the suggestions already given, you may want to find a way to reduce the ballast weight, and reduce the vibrations in your aircraft.
Rafael
Are you thinking off balanced prop or spinner?
